Hi. I'm looking for a wedge type AXA QCTP.
I have a brand new VEVOR 7"x14" mini lathe with 550w variable speed motor and digital display. I measured the vertical distance from the top of the compound to the center of the spindle at just over 0.6 inches.
Here are some of the items I have looked at purchasing:
AXA Size Wedge Type Tool Post 250-111
Amazon ASIN: B07THXG6R6
findmall 6Pcs AXA 250-100 Tool Post Set for Lathe Swing 6-12 Inch
Amazon ASIN: B08K8XLPS7
Accusize Industrial Tools Style Axa, Wedge Type Quick Change Tool Post for Lathe Swing 6-12"
Amazon ASIN: B01AISKZ08
A couple of those mention that a height of 0.60" is adequate, but my concern is related to the parting blade holder. I already have an issue with the stock tool post setting parting tools too high with no shims. Then I saw this comment on Amazon for one of the QCTPs above:
Q: Will this fit a central machinery 7x10 lathe?
A: It fit mine but the cut off blade can’t be used. The height can’t be set properly to use it.
My questions are:
1. These AXA QCTPs seem to require at least 0.60" from the top of the compound to the center of the spindle. I have a bit (about 0.025) more than that. How can I determine if that will be sufficient for the 250-107 parting blade holder to work properly with the QCTP?
2. Why are most (all?) 250-107 parting blade holders angled upwards?
3. What is the difference in the 4 and 7 degree angles?
4. For parting with HSS blades in a QCTP, what tool holder issues should I be aware of?
My questions are:
