- Jan 30, 2011
- 39
Hi Guys. Parting seems to give some people a lot of trouble. Yes it's tricky and takes some practice but here's how I do it. I have a HF 9X20 lathe, Phase 2 QCTP hobby size (I took it off my 7X12 lathe).
Photo 1: The blade I use is from Travers Tool. "P"Type High Speed Steel Cut-Off Blade
Dimensions 1/16"; x 1/2"; x 4-1/2" Item # 55-202-510. Wider tools will chatter more. I believe the key is that the top is hollow ground. That is to say the top of the blade has a concave shape that curves the chip narrower and it flows out of the slot easily. The T Shape has lots of clearance on the sides. I've tried a couple other brands but this one works well on my 9X20 and my 7X12. I had to modify my holder to fit the T shape of the tool.
Photo 2: Make sure the tool is parallel with the face of the part. Very important. The part is turned 2.0"; OD and bored 1.0" ID. Low carbon HR steel. The bore running true make things easier when you break thru. Tool only long as necessary out of the holder.
Photo 3: On my 9X20 lathe. 120 RPM . I used a center with a washer to give support to the part, I'm not holding by alot and I'm cutting pretty far from the chuck. Ideally I would be less than 1/8" from chuck even if it means turning the part around. Not possible with this piece, and a small chuck. Sometimes I use a center even if close to chuck or with a larger part as needed. Your setup needs to be rigid.
Started grooving. I use water soluble coolant applied with acid brush.
If I get chatter then : Feed a little harder, but don't go crazy. I know it's hard but proper chip load is important. Check center make sure it's tight. Check speed (slower or faster there's a "sweet spot" RPM). The chips come out like clock springs when you get a little deeper. Keep that coolant coming. Flood would be great but I'm not set up for that.
Photo 4: The finished cut, I kept the center tight all the way thru. Having the bore run true is good, then the cut-off part just stops turning, I try to switch off the spindle quickly but don't panic. With a little practice you can feel the tool pressure go soft you know it's about to break thru, you can back off the center then if you like.
Keys to remember: close to chuck; rigid setup; narrow tool; short tool length; good grip in chuck; coolant or other cutting oil; proper RPM; proper chip load.
Yes it can be done, a little practice and you'll have it. Sorry guys I don't do video I'm on dial-up.
Good Luck.
Ed Hoc
Good Luck.
Ed Hoc
