- Oct 14, 2014
- 1,979
need to make a weldament out of 316.
found I should use 316L:
Plan to TIG it. any other special weld instructions?
Need to passivate also, never done this or anything like it. read this:
https://www.carpentertechnology.com/blog/how-to-passivate-stainless-steel-parts
This table is the meat of the discussion. No such thing as easy to buy nitric any more.
Found this on Amazon:
So, is 10% just this offer above 10% in water???
Need to heat to 150, can I just do this on an old stove in a restaurant food grade SS pan?
Other things I need to know??
What’s the Difference Between 316 and 316L Stainless Steel? - Alliant Metals Inc.
There are quite a few varieties of stainless steel available for your production needs. If you’re new to selecting steels, then it might be confusing to tell the difference between them. We’ll take a look at two similar stainless steels, 316 and 316L, and explain the difference, so you know what...
alliantmetals.com
