- Jul 13, 2014
- 1,051
When I bought the mill a couple or so months ago it came with a phase converter. The seller said he just used the converter in factory setting, something I never bothered to read in the manual on what that is. Basically been running it with what he had in it.
Have to admit have not done a lot of work with the mill as my learning effort has been on the lathe. I do not know if it is a problem, but the max frequency I can run on the converter is 37 HZ. If I were to go any higher, it faults out and had to crank down and reset. The other thing I noticed even at the 37 HZ setting when I turn on the spindle it spools up real slow.
Questions:
Is that normal performance in that combination?
Or should I RTFI and figure out how to set this box up?
If I were to snag a 2-3 HP VFD, how would you operate the speed control, still use the crank or leave the crank at some setting and control the speed range with the VFD?
TIA
Questions:
TIA
