- May 28, 2013
- 202
Hello All!
I am in the process of firing up the power to my little home shop.
I currently have a RONK, ROTO-CON / MarkII, Model No. 92, Type 2P, phase converter. This item came with the large band saw I purchases over a year ago. When powered by 220VAC, this unit produces 10 amps 3 phase. The tag reads:
KVA Max 4 Volts 240/480
Type 2P/4P Model 92 Hz 60
FLA 10 20/10 Largest Motor 2 Hp
Min KVA 0.5 Base 30 AMPS 10/5
Serial No 419951 Frame 182
The manufacturer told me on the phone to not worry with using a motor starter with heaters, just add a 2 pole switch and fire it up.
I want to ensure things are safe, and maybe I am going over board. But I want some type of protection on the motor to prevent mishaps.
While looking at options, I found this web site: icmcontrols.com. They have a section under phase monitoring and control.
What are your thoughts to using a device like this, rather than the old tried and true, fused heaters?
Looking over the manual, depending on the model, this ties to a contactor and if voltage falls outside of the range set, the relay fires and opens the contactor. Found pricing on Amazon and would be much cheaper option compared to a starter.
Please let me know your thoughts?
Thank you!
Tom
toolman_ar
Thank you!
Tom
toolman_ar
