- Feb 19, 2013
- 6
A little over a week ago, I spotted an import lathe in the back of a warehouse covered with dust, dirt/filth. It is missing the compound dial and handle, the E-Stop flange mount is cracked. The main power On/Off knob is also missing. However, a 3 jaw chuck is mounted on the spindle, it has a 4-jaw, a driver plate, two face plates, a steady rest and a follow rest. It also has a live center and a couple dead centers and an additional set of inside jaws for the 3 jaw chuck. There is a little toolbox that includes several threading gears (metric, i suppose) and a couple of wrenches. The manual says Jesco Machinery Ltd. "Prince" model 1340. The swing is 13" and between centers 40". The dates are 1998 on all doc's and it is a freight damaged machine that was never put into use, or wired. I finally swung a deal with the owner of the place at the end of last week and was able to pick it up, today. I have a couple of days worth of clean up to do (as time permits,) then locate it to it's final address inside my little shop, level it, hook up the Phase-A-Matic, 3ph converter that's been lying around my place for a few yrs and never tested before. Hopefully, that little converter is operable and if so, I will be able to make chips very soon. I am pretty excited about it.
I will try and post pictures later.
Buck
Buck
