- Apr 29, 2019
- 2,099
Spiral point otherwise known as gun point taps are my favorite for all thru holes. Even for a blind hole I will drill extra deep to allow extra room for the chips. If I really need thread to the bottom of a hole then I will use a spiral bottoming tap after tapping as far as possible with a gun tap.
After using a gun tap in a blind hole you can pick out the chips to clean out the hole.
I found out the hard way that not all suppliers use the same color code for material.Also why I mark stock when I “obtain “ it. Which reminds me, I need to find a chart of the colors they use to mark rod stock.
