- May 27, 2016
- 3,469
Here we are talking vintage horizontal twin engines - like 1930s through 1940s vintage.
The bores had corroded, and one piston somewhat scored above the top ring. The poor thing needed the re-bore!
Step 1 was to discover a place that supplies Douglas T35 pistons. I found one in UK that caters to the vintage motorcycle restorers. They had them all, even for a ancient Douglas T35 engine, and they could do it in a +0.020 to suit a re-bore. Bore and stroke and wrist pin size matched all exact.
Step2. The piston supplier regularly supplies the re-bore firm, (Saunders in UK), so they delivered them there direct, saving me a long road trip. The bores are now all beautiful, bored and finished with cross-hatch hone, but that is where I got my first look at the new pistons. Oh dear! This does not look right!
It turns out that the Douglas engines all looked much the same from the outside, but they varied what went on inside depending on the year, and the application. The same 350cc engine was used in everything from generators through to the motorcycles range. Simply changing the crankcase to mount in a bike, using two carburettors instead of one, changing the compression ratio to 8 to 1 with different internal head shaping and piston, gave them a range of low power generators through to as much as 28bhp for the motorcycles. Most of the other parts were interchangeable.
So now, when I compare the new +0.020 pistons to the originals, I think we have a problem! The compression ratio is already low enough without then losing the hemispherical dome!
The hunt is on to find a piston with 5/8" wrist pin, and (freely mixing units), 60.8mm dia + 0.020, with a dome top. i have no idea what could be done to "increase" the compression ratio to run with the flat top. This engine is not for performance anything. It only has to run occasionally, deliver maybe 4bhp or so, for display days of an historic French flying death-trap called Le Pou du Ciel, which will never be allowed to fly.
Now I just don't know what to do!
_ _
__
[ PS: The last picture was from back when I had it assembled and running, from pre-lockdown days, before it got neglected. ]
_ _
__
