PM 1130 motor name plate
Dana_R
Dec 4, 2023
5
I'm looking for the motor specifications (volts, amps, RPM ) for the PM 1130 lathe.
I did contact Precision Mathews for information, they responded that there is no
name plate on the motor. They do indicate that it's a 1.5 HP with a VFD controller.
The VFD is a Delta VFD4A8MS11ANSAA rated at 1 HP. It seems odd to me that the
motor and VFD (HP) don't match.
Just happen to have a brand new motor fresh out of the box.
In reference to the following I have to admit that my knowledge is limited when it comes to VFD controlled AC motors.
Delta VFD model 4A8MS11ANSAA (1 HP) specifications as follows: Output (heavy duty) 1.8 KVA, & 4.8 amps. appears
to correlate with the motor name plate. Specifications found under Delta MS300 VFD web site, Table 9-1, thumbnail
#181. Also in reviewing several different brands of 1.5 HP, 3-phase, 220 v, AC motors ranged from 4.2 to 4.8 amps.
