The only reservation that I had when I bought my 727 was what I initially perceived as a limited speed range. What I have found since I got it is that the majority of the time I only use the 320, 600, and 1700 speeds. The first two have been the speeds I use the most when milling steel, especially the 320. That speed has been a great speed to keep the end mills from overheating since I don't have a coolant system and only use cutting oil. The 1700 has been great for milling aluminum. I read it all the time that speed is your friend with aluminum and most people talk about very high spindle speeds. But, this is not a CNC machine. The 1700 gives a mirror finish on aluminum with a properly sharp end mill. I have found the low 115 rpm speed to be good for power tapping, especially in aluminum and low carbon steel. I simply use my drill chuck and keep a finger on the stop button. Having the forward and reverse spindle power makes this a very easy task to complete.
What I really like about the 727 is the weight of the machine relative to it's size. At approx. 500 pounds, It is not a machine that you will move frequently. But, with my homemade wooden gantry crane on casters, I can move it by myself without issue. I had initially planned to order a 25MV, but, after stumbling onto the 727, I felt it was a much better option for the types of work I saw myself doing. I have been mainly working on tooling myself up by making my own accessories. I have made the usuals: additional tool holders for the lathe, fly cutters, ball turner, dual-dial indicator tramming aid, etc.. I am looking forward to moving into some gunsmithing type work this coming year and I wanted a machine that I believe could handle a bit of steel cutting a little bit better.
