- Sep 24, 2014
- 929
I was asked for a copy of the manual for the PM-25MV. For those of you who are interested here it is! There is next to no information contained in the manual. Matt has told me that they are working on an exploded view of the machine with a parts list specific to the PM-25. One note for those of you who have purchased the mill. The adjustment screw that secures the head of the mill from rotation is made out of something that I think is may be metal, but I am not sure. Mine was stripped right out of the crate. I ended up purchasing a higher grade bolt welding a washer on it and grinding it to the correct profile. Matt sent out a replacement, which is the same as the hold down T-bolts included in the tool kit. I would plan on replacing it right off, because you will be unable to hold tram with the bolt stripped. It is a bit of a job as you have to take the head off, but at least you learn about whats under the hood. I was able to rout some wires for the lighting I added, which makes things nice and clean looking.
Well I was unable to upload the manual. It is 15 pages and must exceed the file size allowed on the site. I am also unable to attach it to a PM, so if you want a copy send me a PM with your e-mail and I will send you the PDF.
Brooks
Brooks
