[4]
PM-30MV
[3]
[10] Like what you see?
daveog
Active Member
Dec 17, 2017
37
Does anyone have a PM-30MV and is using the available stand from PM? I'm between this and the 932M, but it has to go in the basement, so I like the lower weight of the 30. I also like the DC motor with variable speed. But, I really like the extra weight for rigidity and vibration damping on the 932. Also, I like the power Z-axis and the downfeed. The 932 has a heavy cast iron stand available, but only a 70 pound sheet metal stand for the 30. Any thoughts?
Mitch Alsup
Active Member
Nov 17, 2017
487
I would go with the heavier one that has more HP.
The basement problem is a one time problem. The weight and power are a lifetime of joy.
jwmelvin
Active Member
Jan 11, 2018
161
I recently (a year ago) made the same decision. I went with the -30mv because I liked the variable speed and belt drive. I will say when it showed up I was surprised how small it was. I hadn’t really thought about it a whole lot. I do really like the variable speed and quiet smooth running of the belt though. For me I think it’s a good mill but it is not heavyweight.
jwmelvin
Active Member
Jan 11, 2018
161
Oh and I did not get a stand because I plan to make my own. It’s on a heavy metal table right now.
daveog
Active Member
Dec 17, 2017
37
So, how are you liking the 30MV? I wrestled and struggled because all my experience is on Bridgeport style mills. I really wanted the extra weight of the 932, but the drive and ease of moving the machine won me to the 30 and I put a deposit on one today. I just don’t have the room for a Bridgeport in my basement or an easy way to get one in or I’d have gotten one. I talked to Matt and he assured me that for my projects the 30mv was more than enough. Crossing my fingers. My biggest fear is getting it and then kicking myself for not spending the extra money... but the extra is a quite a bit. I ended up getting it with the DRO and x power feed. I also got the PM stand. I would rather a heavier stand, but I think I’ll bolt it down to the concrete.
Chewy
Active Member
Feb 28, 2016
34
I have a PM-30MV on the factory stand. It is OK. I mounted it to a heavy duty homemade roll around stand at this time. I am redoing the shop and don't have a permanent location for it yet. The stand is fine and the machine works well a little off level if it has to be moved and used. The machine is not a heavy weight but it does everything I have asked of it. Don't let size fool you, It will break an end mill or launch a pice of metal if you make a mistake. I like the variable speed over the 932 and that is why I bought it.
daveog
Active Member
Dec 17, 2017
37
That's good to know, thanks. I'm hopeful that it will meet all my needs. I'm looking forward to the variable speed DC motor. All of my other machines, including my current lathe, have always been with a 3-phase AC motor and VFD.
daveog
Active Member
Dec 17, 2017
37
So, I went ahead with the PM-30MV. I anchored the stand to the concrete and it seems pretty stable. I shimmed it and it’s pretty level. I haven’t done much with it yet. I just installed the X power feed and am waiting on a Z power feed to arrive from Priest Tools. I’ll do a write up on that when I get it installed.
[5] [7]
