- Jan 7, 2016
- 3,319
No, jeepers! That would be very expensive. I just keep mine around so I can buy more tools. (just kidding)Got it, bigger mill, new wife,
Since the table is marginally bigger, sounds like "bigger" is more about the mass and rigidity the 833TV brings over the 728VT... while the 833 does have more quill travel and max z axis height.
I'm not really looking for bigger, but I'm also trying to avoid something that I'll be constrained with right away. It's always a toss up... I want the biggest and smallest machine that's of good quality.I've been very happy with my mill, however if you are even thinking bigger might be the way to go, then you may be right.
PM pairs the 728 with a 4" and the 833 with a 4" or 5"... so my guess is that those are right size given the machine. I wasn't sure how much a fixture plate can do and it seems they are super useful. Seems similar in concept to my welding table with 5/8" holes on 2" centers... it's great with all the accessories and tooling to make setups easy.The extra 1-1/4" of table width could be the difference between comfortably fitting a 6" vise or not, but I'd check with others before counting that as an advantage. It may still be too small to recommend a 6" vise. I know even a 5" vise is pushing the limits on my 6x24" table, a 4" being much more suitable. It seems like most with PM 7"x mills tend to favor 4" vises as well. If the 833 can take a 6" vise that is a definite advantage in its favor, and it could certainly take a 5".
The 5" x 7" x 15" capacity is super helpful.I'd guess most of these smaller mills can manage a part 12-14" long, X axis (working area not total length) pretty easily but I'd think 6x6" in the X and Y is the upper limit of comfortable, the 833 would certainly expand the size capability by 2-3" in these dimensions.
Twice the weight is also not an insignificant factor, but unlike the dimensional stuff where it fits or doesn't, rigidity can at least be addressed to some extent by taking smaller cuts. Of course if it appears the 728 is plenty of mill for you, lighter and cheaper can certainly have their own advantages.
Think about the size of the projects you have planned and imagine setting them up within the travel distances of the 728, I'd use 5x7x15" to be conservative and leave some room for the occasional slightly larger project.
The larger X,Y,Z travels make the 833 more useful. Everything you do, to adding work holding, to cutter diameter reduces your work envelope.but looking at the over all dimensions, it's not like it's much bigger
@Aaron_W
No particular project, which does complicate it, I just know aluminum is probably all I'll every put in it so the fact you've had no power issues with your Clausing 8520 is a good reference. I know I can always take lighter passes on a smaller machine but I feel at some point that's true if I got my file out and machined that way. Does the 833 with 1 extra HP and double the weight/rigidity really double what the 728 can do... maybe, hard to tell, so many factors I assume to make a blanket statement.
Certainly have something to think about. If both are in stock when I pick up my lathe in Oct/Nov it may be a last second decision.
Just as an FYI I would not put a 6" vise on an 833TV mill. I had a 5" on mine, and I felt that it was a very nice size for it. Now that I have a large knee mill, I also have a 6" Kurt vise. I have a hard time imagining that 6" on my 833. There are a few threads on here where someone has asked about vise sizes on an 833.
I didn't even think about that. The 728 indicates 8.75" and the 833TV shows 11.75". That does seem like a pretty big advantage.but here is a kicker:The spindle to column dimension matters
I hear ya... I'm tooling up from scratch for my PM-1236T and well, I'm feeling the expense. Just a good set of basics, I'm already over $1K. That's just an Aloris QCTP (20% off) and several tool holder from latheinserts.com (BTW, great experience working w/Curtis) and some miscellaneous stuff.. still need to order several more of PM's BXA tool holders.Every time you have to 'change up' a machine tool it costs a lot of money. Not just the sales price versus the buy price. Also tooling changes, and there's moving stuff out and moving the new one in.
Yea, I'm starting to look with a bit more intension at the 833TV.But if you can afford the 2" greater work envelope in X,Y and Z, you will never regret it.
Yea, seems like the R8 on both the 728 and 833 is a great setup.I'd say the biggest drawback to my mill is the MT2 spindle. Not a huge issue, but it does limit some of my tooling options. The 728 has an R8 which is super common, so tooling won't be an issue.
When I looked at a machine collection for sale, I passed on the Clausing 8520 because it wasn't significantly larger than my pm-30mv. It certainly would have been a big upgrade for work within the smaller envelope, but I knew I wanted both more rigidity and a larger working envelope. Other people have different requirements (or just weight them differently). The -30mv's belt drive played a significant role in choosing that machine over one that was larger but had a gear drive. I'm not sure that was the right tradeoff, now that I know how much rigidity and mass matter at times. The -833tv is a significant step up, in my view; the price reflects that.
