I’m looking at these 2 precision Mathew’s mills. Yesterday I was convinced about the 833. I am sort of convinced I want a 6” vise, looking at a GMT CNC, because it will work on its side, it has decent reviews, has an integrated fixed jaw, and is far less bucks than a Kurt, while seemingly nearly as good, maybe better in some ways. (Anyone have a Glacern Vise? your thoughts?). And 600 v 900.
so The 6” will —fit— on the 833, but is a bit oversized. I’m enamored with the 6” as there are a ton of off the shelf jaws, dovetails, sine jaws, fixtures, etc for the vise.
I mocked up the 935, and it will fit. A little tight, but as long as I don’t push the headstock way back (I don’t remember Ever doing this with my Bridgeport experience, but maybe my memory is poor, and maybe I’m missing a capability—but I can’t do this at all on the 833).
But 2500 bucks more. Thoughts? advise? has Anyone out there hands on both these machines?
Next, what are competitive alternatives? These machines seem like a LOT of value for the buck. Maybe the fit finish, precision, accuracy are lacking?
anyone have experience with the Turcite way treatment? I’ve read it is smooth as glass provides excellent stiffness, and maybe even a hint of damping?
Yes, I understand the Knee mill, at 2x the mass, is going to be far more rigid, but most things I’d be doing would not require insane rigidity. I’ve watched some vids of 1/2” end mills in Steel on the 833, and it looke just fine. knee mill nice? Sure. Will I notice? I don’t think so. I’m really looking for precision, accuracy, smoothness, and a 6” vise.
give up on the 6” vise, and save the space and coin?
also, the VFD on the 833 is key. I’m NOT a fan of changing belts, and the belt drive variable heads can be noisy. But then I could get a VFD on the 935 with a 3 ph pulley head.
anyone added a VFD to a PM pulley head?
Jeeze, probably no one will have read this far. If you did, I’m grateful.
what is your experience?
