- Jan 16, 2016
- 302
I FINALLY FINISHED UP MY DRO INSTALLATION NOW THAT I HAVE A CHIP TRAY UNDER PM-833T MILL .
WHAT's NEW IS A LOWER COVER FOR THE Y SCALE AND A 1/4" ALUMINUM END CAP .
THE UPPER COVER HANGS OUT FARTHER THAN THE LOWER ONE SO ANY CHIPS THAT GET DOWN THERE WILL FALL ON THE OUTSIDE .
THERE IS A DRAG CHAIN INSIDE THAT HOUSES BOTH THE X & Y CABLES .
IT ANCHORS IN THE BACK AND TRACKS PERFECTLY THROUGH THE RANGE .
THE Z AXIS CABLE ALSO RUNS THROUGH A DRAG CHAIN THAT HOUSES THE POWER TO THE MOTOR AND THE LED WORK LIGHT
THAT MOUNTS AROUND THE SPINDLE . CHIPS NEVER GO THERE BUT I MAY TRY TO MAKE A COVER FOR THAT ONE TOO .
