I am setting up the VFD to drive the 3 phase motor on my mill. For that I need to know the motor full load amps (FLA). Unfortunately my motor nameplate is not stamped correctly. It shows 6.2A for 220V. 3 HP motor should have higher FLA. Matt assured me that I have a 3 HP motor, just the nameplate is misstamped. Variable speed heads for 949 mills always come with 3 HP motors. Amps data stamped apparently came from a higher voltage motor.
Anybody has a similar 3 HP motor? Would you mind telling me what your FLA is for 220V supply? Your help will be greatly appreciated.
By the way, this motor is of open design. It sucks the air from above the motor, routes it around motor coils and blows it out of belt housing vents. This may explain how they could build such a light weight but powerful motor. It weighs only 52.6 lb complete with pulleys. Need to remember to put some fine mesh wire cloth over the motor top to protect the motor.
Since I took the mill apart for moving I weighted all major components. If anybody needs the weight data, let me know.
