[4]
PM1236 5C Collet Closer upgrade
[3]
[10] Like what you see?
Grimstod
Newbie
Mar 17, 2018
6
Likes
12
#1
So I did a bunch of research before I jumped into this project. Basically I checked the spindle size and made sure the taper was the same. Also looked at the length of the spindle. After all that I figured I could make the Grizzly 5C collet closer for their G3004 lathe work on the PM1236. You can see here a quick run down video of it in place. Works pretty good. The first draw tube Grizzly sent me had a ton of runout and shoot the lathe so I sent them a video and they replaced it. Pretty happy with it. Hope those of you who have Precision Matthews excellent PM 1236 lathe could find this info useful.
Silverbullet
Gold
May 4, 2015
3,420
Likes
1,673
#2
I wouldn't get another lathe without a lever 5C collet set up. My first lathe was a Sheldon and I had the lever collet set with it , I was doing sub contract work in my shop and I tell you the most used item was the collets. Hardly ever had chucks on the lathe. With the right set up oversized machinable collets . Even square hex, rectangle . Special ordered even . I had a tailstock turret that helped too. Time was everything to making money , accuracy and quick turnaround makes the shop name. You did a good job adding those good luck .
petertha
H-M Supporter - Gold Member
Jan 15, 2016
664
Likes
428
#3
I've got a similar sized lathe & 5C collets using conventional collet chuck, but never really seen these lever closers in action. Is the general idea that you part off a completed part, open the collet with the handle, advance the stock, lock the handle, rinse & repeat? Or I guess also load semi finished parts in too. I take it the advantage is time reduction? How is the runout on these units?
Grimstod
Newbie
Mar 17, 2018
6
Likes
12
#4
These units tend to have very low runout. Usually in the tenths.
[6]
[5] [7]
