P
pepi
Forum Guest
Register Today
See if I understand the pin was behind the set screw. If that is the case, that sounds like the set screw should have been longer and that was mickey mouse work around. If it were me I would, check the size of the pin and if it has the same OD as the allen.
I’d opt for an allen that matched the added length of the two pieces.
Second choice if pin OD is smaller than the allen; machine the end of the allen to the length and dia of the pin.
My 2 cents
