- May 18, 2015
- 231
What I thought would be no problem ended up being a pain and I can't figure out where to go from here.
My plan was to leave the table on the saddle and remove them both at the same time with the help of a neighbor. I removed the Saddle GIB and Screws, and the Y-Axis Lead Screw and Bracket. I don't recall exactly what else I removed but there was nothing left holding the saddle in place. I thought lifting the Saddle sideways at an angle would disengage the ways, but I was obviously wrong. So we moved the saddle forward but it won't slide off the front because the nut for the Y-Axis Lead Screw is in the way. And I can't remove it because the bolt(s) are under the Table.
Not to be deterred, I removed the same/similar items that keep the table in place only to have the same problem. This time the bolts holding the nut for the X-Axis screw come from the bottom and I'm not sure how to get to them without a wrench with eyes and the flexibility of a contortionist.
At this point I'm going to email Matt since it was his idea to remove the table to begin with, but in the meantime if someone knows where I went wrong please let me know. And I'm only referring to the lathe... my ex already told me where I went wrong with everything else in life many times. Don't want to go there again.
