- May 29, 2014
- 188
I may be over-simplifying things, but how about forgetting the lift and use a couple of wooden blocks on the table and a short chunk of 2x4. Loosen the bolts a small amount and pry the front up--insert shims--lower back into position and tighten & check--rinse & repeat till done. If the rear needs shimmed, you won't even need to lever it--should tilt forward with the weight alone. It would appear that the bolts shouldn't need to be loosened much more than 1/2 -1 turn to insert shims. I am going to need to do mine soon, also.
Jerry in Delaware
Jerry in Delaware
