- Oct 4, 2016
- 7,030
I recently moved my 5hp RPC from a fused 30 amp disconnect, and moved it to a 50 welding outlet. So I started the RPC to run my DoAll bandsaw, and had to do something else, and cut power, I finished what I had to do(not as long as I thought) the RPC still had a decent RPM going winding down, and I hit the start button with a brief hold. That is when there was a pop with magic smoke from the cabinet, and the start capacitor lost it's containment. Luckily I did not shut it down, and I was able to make the cuts without issue. Now the capacitor is 340-408um, did I cause the failure by the restart, or moving to a 50 amp circuit, the RPC has a 30 amp breaker on the box?
