Hi, noob here.
I'm machining a few small parts for usage on the floor inside of a car. So, it isn't a boat or anything, but there is definitely the potential for it to get damp occasionally.
I'm trying to use as many off-the-shelf parts as possible, but the machined component is made out of mild steel. It's basically just a piece of mild steel that's internally threaded to accept a bolt. Then I'm hoping to thread a regular bolt into it.
Here are my questions:
1. If I thread a zinc-plated bolt into that mild steel part, along with a zinc zellow chromate plated washer, how severe is the potential for corrosion between any or all of those components?
2. What can I do to prevent corrosion in the threads? Will loctite help with this?
3. Any other thoughts or suggestions?
Thank you in advance.
