- Mar 26, 2018
- 8,415
Nice shop!!!I use Servo power feeds on two vertical mills I have now. The 200 type is on the knee as per Servo’s recommendation – especially on the larger mill. Through the years I’ve mostly run Servo, but I have had an Align power feed which worked fine. The biggest difference between Servo and any of the others I’ve tried is that Servo is a little smoother throughout its operating range and seems to have a little more torque at really slow speeds.
One thing that makes Servo more expensive is the need for a special hardware mounting package for each mounting situation. You can save a little money if you make your own. It isn’t too hard.
Here are pictures of the mills with the power feeds. By the way, I don't think you'll regret putting one on the knee whatever size mill you have.
View attachment 469982 View attachment 469983 View attachment 469984
Servo brand is for rich people or professionals.
