An India stone is also appropriate, I have used one for removing scraping burrs for many years, my thinking is that the so called "precision stones" are more faddish than necessary for anything that most of us do.
It is worth pointing out an India stone is just Norton's name for an aluminium oxide abrasive stones (I didn't realise it initially). Unfortunately Norton's products are hard to come by around here and it's good to know one can use any other good quality aluminium oxide stone instead.
Personally, making a set of such precision ground stones has been on my lisf for quite a while. I do have a surface grinder with a diamond wheel, but I haven't got any way to hold the stones on my magnetic chuck yet. I have to make some magnetic hold-downs as shown by Rob Renzetti.
Area they necessary? It depends. Are you trying to hit the best tolerances using high quality precision ground tools? If you do, they sure are handy from what I saw. However, if you don't have them a set of reasonably flat bench stones is a good replacement providing you're aware of their limitations.
For example, I use cheap non precision ground stones flattened "by hand" on a diamond stone flattening tool to stone my surface grinder chuck as well as parts that are surface ground up until the final surface. But I'm aware a non-precision ground stone actually removes some material (as evidenced by it getting packed in the middle). I tend to use my hand to detect dings or burrs, then I run the stone very gently over the surface looking for any signs of raised areas. Finally if burrs or dings are present I run the stone only over area affected.
Also, I would never run a "normal stone" the way one can do with a precision ground one on my really good tools (for example my best sine plate).
So in summary, are they necessary? Sometimes yes, but one can substitute "normal" good quality stones in many uses. It is important to use the correct grit and good quality (consistent grit throughout the stone) however.
In general finding good quality bench stones in grits we need (~200/400~600) has been really hard recently. It seems most such stones are sold for "sharpening" and for this they tend to use grits like 160, then 600, then 1000. If one never had a good quality stone in correct grit size in their hand it may be difficult to judge quality.
If I ever find good quality bench stones for a reasonable price I can get here in EU I might precision grind them and I may try selling some on ebay.
