Preferred spotting for drilled holes?
macardoso
H-M Supporter - Silver Member
Mar 26, 2018
1,218
I run a smaller CNC and would like to preset a single tool to handle most or all of my spotting work. When doing general drilling I have always used a small center drill, but need to run high RPM's and find it doesn't clear chips well. I see NC spotting drills for sale in angles ranging from 90 degrees to 150 degrees. What would you recommend for a general purpose spot drill?
rgray
Nov 26, 2012
1,307
I assume your using screw machine drills.
They usually come in 118 deg and 135 deg.
So if using the 118's get a 120 spotting drill and if using the 135's get a 140.
rgray
Nov 26, 2012
1,307
If you use a larger spot than the drill being used, and get the depth right your hole will be chamfered before it's drilled.
Great benefit.
macardoso
Mar 26, 2018
1,218
I haven't acquired many screw machine drills. Working off of a mismatched set of 115pc jobber drills. Bought cheap and replaced with cobalt and a few carbide over time. I should get a second index of screw machine drills.
That's a solid reason to use a 90 degree spot drill
mikey
Global Moderator
Staff member
H-M Lifetime Diamond Member
Dec 20, 2012
7,297
Not sure I follow the 90 degree spot drill thing. If you plan to use a spotter, the included angle of the spotter is typically larger than the angle of the drill in use as @rgray said. I do agree with the use of screw machine drills; they are much stiffer than jobber drills. Once you have a set then choose your spotting drill accordingly.
The chamfer thing has to do with using a spotter that is larger in diameter than the drill in use. For example, if you used a 5/16" spotter to near full depth with a 1/4" drill, you would have a chamfer left over. It will NOT be the correct chamfer angle for a screw but it will be nice for appearances.
MarkM
Apr 23, 2017
495
If your not worried about the chamfer and want an accurate hole without the need to spot you could use a four facet drill and save that operation for most work. They tend to drill a more accurate hole closer to nominal size as well. I really like my Tormek wet grinder and the dbs-22 drill sharpening drill jig. Does a fantastic job with the four facet and can doctor a drill up for whatever material I come across. Not cheap but well worth it!
Tornado220M
Jan 22, 2020
2
I just use solid carbide which I can run so much faster on speed & feed.. also lasts longer and maintains a surface finish much smoother than a HSS or cobalt mix can.
AdBlock Detected
I've Disabled AdBlock
