- Oct 16, 2017
- 338
I went to cut an external thread, set the compound at 29.5 degrees and one of the bolts would not tighten. Removed the compound without rotating and low and behold the lock nut is positioned exactly at the insertion point. Any ideas how to fix this? This just happened, I have cut many threads with the compound at this position. It is to the point where I can no longer lock the compound base anywhere near 29.5 +/- 2 degrees.
