- Oct 31, 2016
- 2,649
I need to turn down an aluminum tube, 1.375 OD by 1.125 ID, to 34mm OD to fit inside a rigid boom vang for my sailboat, I would like to do this between centers but don't have a live center for the tailstock or a dead center for the headstock big enough for the tube ID. I could 1) make adapters that would fit on the live and dead centers that I have, 2) buy a live center for the tailstock end and use a 4 jaw to hold the headstock end or make an adapter like in option one for the headstock, or 3) 4 jaw on the headstock with a steady rest for the tailstock. Turn the tube down to 34 mm except where the steady rest is and then move the steady rest to turn down that portion of the tube. The tube is 16" long. I only need just over 14" for the part that I am making. It would be a tight fit to have the steady all the way to the end and turn between the 4 jaw and the steady. Might not be enough room.
Suggestions please.
Suggestions please.
