Guys I have a project in mind I need some help on .
I think the nature of the project will become self evident soon enough on its own so ...
The first thing I need some help on is making a D bit .
I need someone who can properly grind and sharpen the bit for me
I have no way to grind at the moment .
I'll cut the profile I want on a piece of 01 drill and mail it to you.
And I'll include return postage with it .
If you are experienced at hardening and tempering tools and want to do that as well I wouldn't say no , but I'm confident enough to do that myself .
The second item I need help with amounts to a piece of aluminum stock .. .750" x 1.5" x 3" with a .325 x .325 slot milled down one side length ways
The picture should show what I need somewhat more clearly .
And make the project self evident.
None of the dimensions are critical. .. steel rule close is good enough .
The drawing shows one finished surface ( if you can decipher it )
I can do that Easy enough ... all I need is the slot milled out
I'd be very happy to pay for materials and your time .. if you can do it but don't have any material. ... no problem I'll send it to you .
Thanks guys
Thanks guys
