Thanks for posting this project, especially all the high resolution pictures. I'm thinking about tackling a similar project and had some questions:
1. I'm having problems finding the timing belt and pullies that you used. Where did you get them?
2. Also, why did you go with a timing belt instead of a v-belt or two? I'm not seeing a slip clutch or shear bolt to protect the tractor's drive train if the pump seizes up. V-belts could offer a bit of protection because they'd slip or break.
3. I'm also not seeing an unloader or a relief valve? When the wand valve is closed, the pump is going to build up pressure/heat after just a few minutes. Has this not been an issue for you?
