background: I bought a homemade mill from a friend and he didn't know the rpm of the original drill press but fortunately there was a table of speeds on the sides for the 5 original pulleys: 3100, 2340, 1720, 1100 and 620.
The pulley diameters for both drivers and driven are 1.75, 2.25, 2.5, 3 and 3.5" on each cone.
Also, I could measure the diameters of all the pulleys, driven and driver pulleys AND I own a 19th edition of Machinery's so armed with all of this data, I began my quest with the ultimate goal of measuring the rpms of my fabricated compound pulley.
So in order to do the math on the compound pulley, I started with finding the drill presse's rpms from the motor shaft.
According to my handbook, the rpms can determined by multiplying the diameter of the driven pulley times the driven speed. That total will then be divided by the driver pull.
So the math works out to 3.5 X 620 / 1.75 +2,170 rpm at motor shaft.
1. Correct?
2. In figuring the diameter for pulleys, my handbook tells me to measure the tops of each pulley. I'm sort of puzzled by that because it would seem to be more accurate to measure the bottom of each pulley trough. The reason I say this is because different pulleys have different trough depths. In any case, I'm not too concerned about this because the discrepancies will be negligent. Just wondering.
![DSC05674.JPG DSC05674.JPG](https://www.hobby-machinist.com/data/attachments/29/29332-814fed4b2df0770692acd4117763b1bc.jpg)
1. Correct?
