I did a search, but didn't see an answer to my question. I needed to replace the felts on my newly acquired Heavy 10 so while I had it apart, I am refinishing and taking the time to perform any needed maintenance.
I have the QCGB apart and stripped. In the rebuild guide it says replace any bearings that need it. This is where I am not sure if this is simply known by experience or if there is a quantitative way for me to determine this. While I am pretty mechanically apt, but this is my first lathe and I don't know how much wear is too much.
Can I simply check the bronze bearings inside diameter and then check the steel shaft outside diameter to determine wear? Or is it more of a feel thing?
Also on the roller bearings, should I just replace them? They were a bit tight after cleaning in degreaser, but I put some oil in them and they loosened up, but I have no idea if they are ok or not. I lean towards just replacing everything now and doing it once, but if it isn't needed, I hate to waste the money.
Anyway, what is my best option for knowing if these items need replacing? If they do, what is the best source for bearings?
This is my QCGB as it sits right now.
![SB%20QCGB%20Bearings-XL.jpg SB%20QCGB%20Bearings-XL.jpg](https://www.hobby-machinist.com/data/attachments/181/181473-346d60f62394484c01ebf60498040a98.jpg)
![SB%20QCGB%20Bearings-XL.jpg SB%20QCGB%20Bearings-XL.jpg](https://www.hobby-machinist.com/data/attachments/176/176534-346d60f62394484c01ebf60498040a98.jpg)
![SB%20QCGB%20Bearings-XL.jpg SB%20QCGB%20Bearings-XL.jpg](https://www.hobby-machinist.com/data/attachments/178/178566-346d60f62394484c01ebf60498040a98.jpg)
![SB%20QCGB%20Bearings-XL.jpg SB%20QCGB%20Bearings-XL.jpg](https://www.hobby-machinist.com/data/attachments/179/179008-346d60f62394484c01ebf60498040a98.jpg)
![SB%20QCGB%20Bearings-XL.jpg SB%20QCGB%20Bearings-XL.jpg](https://www.hobby-machinist.com/data/attachments/180/180879-346d60f62394484c01ebf60498040a98.jpg)
![SB%20QCGB%20Bearings-XL.jpg SB%20QCGB%20Bearings-XL.jpg](https://www.hobby-machinist.com/data/attachments/180/180904-346d60f62394484c01ebf60498040a98.jpg)
