- Feb 27, 2014
- 2,130
I just got my compressor back together today. Same old compressor (1958 2 stage Curtis but just rebuilt it with new gaskets and an overall good cleaning)) on a new tank (80 gal) with a almost new motor, new pressure switch and plumbing. The old pressure switch was set to cut out at about 150 PSI. The new switch I bought defaults to just under 180 PSI. The tank and all are rated at 200 PSI. I am curious what others think is the ideal pressure. The primary use of pressurized air is for a Fog Buster system on the mill to cool the cutter and help evacuate chips. I also use to air up tires. I have a few air tools. I don't do any painting or sand blasting. Will it last longer if set to 150 PSI? Will cycle more often or less often when set to 175PSI? Thoughts?
Thanks all
Thanks all
