- Nov 22, 2010
- 371
I am restoring a logan model 820 Built in 1945.. the " door" cover that encloses reverse gear and idlers APPEARS ... to be a brass or bronze casting....is this normal ????. the base pieces ( That support the bed ) appear to be cast iron but seem to give off a cold color within the grain od the cast iron...
I have stripped of the paint and removed the origional Graphite blue on all parts preping for paint with hammerite ( a 50/50 blend of hammerite Dark blue hammered and hammerite Black hammered. the resultant color in close to the origional blue with a metalic flair and a hammered finish. Certainly not origional but awsome to my eye
I am curious if the war caused the use of something different or that was just what they did beac then.
Any input from you Logan Masters woulebe appreciated
Thanks
joe
Thanks
joe
