Hmm backfeeding voltage?Ironically, it is possible that a motor startup load on 110 can cause your lights to brighten rather than go dim. Can you guess why?
While we think of neutral as always being zero volts, the reality is that if you run current through your neutral wire, there is some voltage drop on it. On large startup currents, that peak startup current causes voltage drop on the hot wire, but voltage RISE on the neutral wire. Well, it's AC, so the neutral voltage moves toward one of the two hot legs. That reduces the voltage on the loaded hot wire, but increases the voltage on the "lightly" (pardon the pun) other leg.Hmm backfeeding voltage?
Where it gets a bit interesting is looking at startup current. Motors can easily peak at 2-3 times rated current or more, very briefly, during startup. This can and often does exceed the rated breaker current. It occurs briefly enough that wire heating is not a fire hazard, so this is acceptable behavior.
My 20hp RPC idler peaks 210a on startup. That’s big enough for me. That amount of current/voltage for 8000hp just frightens me.Thumb rule we always use is about 5x running current. You haven't had fun until you start an 8000 hp motor and watch it peg the gauge to 1600 amps for a solid 30 seconds on 13,800v...
