- Mar 26, 2018
- 8,407
Hi all,
I hope you are well.
This is a set-up and chatter question.
Over the weekend I made some progress on my rotary table pallet-work table.
I don't have very much experience with boring on my mill.
It's a full size Sharp 3hp knee mill. I locked down X and Y, I used the auto down-feed feature at slow and medium with different cut depths ranging from .025 to .075".
I held it down as sturdy as I could think of. I placed the 2-4-6 blocks inward to reduce chatter. I started out with a 1/2" hole, I am boring to a depth of .500" and I'm going out to 1.625"
This is a 2" Shars boring head. I started out using a Criterion boring bar which I touched up and honed but found it had too much flex as the chatter was bad. I switched to a shorter and thicker bar = same issue.
The boring bar I am using in the picture allowed me to get the job done. The finish was very good.
I had to play around with feeds and speeds as the hole got bigger. I went into back gear around 350 rpm at the end.
My question,
Is there a better way to stiffen up the part?
Is there something wrong with my set-up?
Ideas?
Thank you.
My question,
Ideas?
Thank you.
