- Apr 29, 2019
- 2,071
My furnace always seems to run fairly short cycles. These short cycles are being commanded by the thermostat.
My question is, How short is short?
As is a typical cycle lasts about a minute from the time the Furnace blower kicks in to the time the thermostat is satisfied and ends the call for heat. It will then be just 1 to 10 minutes depending on outside weather till this repeats. I would think it would be more efficient to have the furnace run fewer longer cycles.
In the setback mode, I have it set back 10°F at night, It only takes about 10 minutes to have the house back up to temp at the end of the setback.
Does mean my thermostat is to sensitive?
Or maybe is my furnace to big for the house?
I have looked inside of the thermostat for any kind of anticipateor type of setting, there are no internal adjustments of any kind I can find as seems to be the case with most electronic units.
