I am trying to design an electronic cigarette mod. Pretty much just a flashlight with a momentary switch and a heating coil rather than a LED or mono-filament bulb.The battery I am designing it to accept is an 18650. Obviously it can not be and 18mm diameter tube otherwise there will be no tolerance for the battery to fit. I am planning to make it ~18.5mm . I was thinking I could use a 3/4" tap for the threaded hole as this is quite close to 19mm. I would like to use my lathe to make the threads but I feel a tap will be easier as I am inexperienced with this. The battery tube will be stainless steel and the top cap will be copper. The atomizer connection is a 7mm x .5 thread. Again I plan to use a tap for this, I am also not sure if this small of a hole would be possible for me to thread with my lathe but I would imagine so.
The bottom cap will be a press fit. It will be a copper bottom cap pressed into the stainless steel battery tube. What is the procedure for press fitting? How close of a tolerance do I need for it to press in and hold properly?
Thanks in advance for the help guys! I look forward to learning how to use my lathe and maybe one day getting a mill. I wish I had the money for CNC but it's just not there.
