Another approach would be to make it easier to use the current fastening system of your chucks. I made a little nut starter that works pretty well:
A small super magnet is glued on the back to hold the nut in place. To use it, insert a nut into the slot, then use the tool to push the nut against the rear of one of the studs and rotate. Once the nut has been started, just spin it down with a finger. Tighten as usual.
Since the nut is held in place using magnetism, the tool can't be made out of steel. I used aluminum.
