- Mar 20, 2013
- 153
On a Dayton 1 1/2hp motor wired for 220, is there any way to slow the ramp up time when it is first energized?
Hawk
Hawk
Zero, when you say installed, is that something fairly easy to do or should I take it to a pro? Ok looked them up and it appears they would be connected somewhere in the line to the motor. Would it go in the line before my drum switch?A Soft Start can be installed.
It will reduce the startup current and torque.
They are usually adjustable foe start current or time.
220 single phase. It was set up w an invertor and 3 phase motor with all low voltage controls. Had a problem and they quite working so I replaced it all with a simple single phase motor and drum switch. I had the invertor for the three phase set up w a 6 sec. ramp up time. With the single phase motor, it is jarring when you hit the switch and it instantly comes to life.I agree with @Ulma Doctor a VFD seems like the way to go and you get many other features to boot. I haven't used a 1-phase-1phase VFD but assume similarity to 1-phase-3-phase unit.
Aaron
This is typical of a single phase motor of this size. There's not much you're going to about it, that I know of anyway.With the single phase motor, it is jarring when you hit the switch and it instantly comes to life.
