- Feb 25, 2012
- 8
I am trying to re-barrel a M1912 Norwegian Krag rifle that has already been sporterized. The barrel is almost unbelievably corroded. I am experiencing tremendous difficulty removing the barrel. The threads on Norwegian Krags are left-handed, so I am turning to the right. Norwegian Krags do not stop on the shoulder of the barrel shank like most rifles, threads are exposed and the stop is provided by the inside of the receiver. I suspect it is heavily corroded. I soaked the action in 50/50mix of Automatic Transmission Fluid and Acetone (according to Machinists Workshop magazine this is the best un-sticking concoction tested vs. Kroil, PB Penetrating Catalyst, etc.) for days. I clamp the receiver ring in my barrel vise with generous application of rosin. Yard long 1/2 inch cold-rolled steel rod is now bent using it to turn off the cross-drilled barrel. The the action started slipping...
The action is rather fragile with many thin steel ribs and sections and the magazine bod. I had the idea of casting the entire receiver into a block of Cerrosafe (this is about $300 worth of Cerrosafe) and putting that into a vise. Not cheap, but an option.
At what point should I consider milling out the barrel? Any tips along those lines? Also, I am unsure of the features of the receiver and don't want to cause any damage. I do know the minor diameter of the barrel is 1.001 inches.
Any help would be appreciated.
