- Jun 7, 2013
- 10,089
I wonder if those pulley taps have a high carbon shank welded to a HSS "business end", as is done with drills, where the shanks are left relatively soft; this is done for purposes of good grip when chucking, and economy.I have used broken pulley taps to make micro cold chisels, engraving tools, and center punches. I grind the profile that I need and heat the struck end to a red heat to anneal it. I had one 1/4" cold chisel that I used to cut a keyway in a piece of shafting before I had a mill. The steel is stronger that W1 or O1 and there is almost no danger of pulling the hardness when grinding.
Otherwise if the taps were all HSS, heating red on the drive end would have very little effect on hardness. Lathe cutting tools and such as planer tools on long cuts can be seen at red heat at the point of contact with the work, this I have seen, and it does not degrade or destroy the tool, the trick is to use enough feed so that the superheated area of the tool falls behind the cutting edge, if this is not done, the cutting edge will be destroyed and the tool need to be reground, but the red heat will not substantially degrade the tool's abilities to cut after being reground; red heat does not have much effect on HSS so far as reducing its hardness.
