I have one that was a home made one from the 70's.
The guy made it from plans in some engineering magazine.
It has a reciprocating hacksaw and a double grinder on the other side.
It is a bit slower than a cutoff bandsaw but it cuts straight and clean every time!
What i like about it is you set it up, flip the switch and away she goes!
You can go back to working on the lathe or browsing www.hobby-machinist.com while you wait!:thumbzup:
It should have an auto off once the cut is done.
Power hacksaws provide lots of cheap, straight cutting. Stroke on that saw is more like 5 or 6 inches. I had an old Keller that I rebuilt, used for many years, and sold to a friend of mine. It's still going strong. Hope you got it!
Great to see it worked out for you and you got a good machine.
That machine will save you many hours with being able to do something else will it's cutting, not to mention not having to do it by hand.
