- Feb 1, 2015
- 9,690
I have a small pair I picked up at a ham fest for $1 each. I use them for holding two parts in approximate position while I tack them. I don't rely on them for precision alignment as welded parts will move when the welds cool anyway. If I need a precise 90º, I check with a square after tacking on both sides. Then, after completed the weld, I will check again and adjust. Another method to help ensure a square assembly is to clamp a diagonal bar to the two parts. Vise Grips work well for this.
