I honestly have never needed bluing to last a long timeI still prefer dykem over sharpie. The dykem lasts longer.
The Sharpies are ok for quick layout & a quick cut but I also find they don't last long. If you ever need to make a part that requires quite a bit of layout & handling then proper layout fluid is so much better. Even layout can wear off eventually depending on how much the workpiece is handled.I honestly have never needed bluing to last a long time
When I lay out a series of hole locations or layout lines I usually permanently mark the spots once laid out. I don't generally expect Sharpie to be there long. I haven't used dykem in a decade or longer. It's just not the kind of work I do.I don't use a lot of layout "fluid" - A used can of dykem came with my lathe 8-10 years ago. I've had mixed results with it, I think it's thickened up and doesn't go on evenly. (duh - it's ancient prob 40 years old and I should just get a new can if I'm going to use it).
So I mostly use the big fat sharpie. I will agree with others - the sharpie comes off quite easily both cutting oil and waxes and also cool-mist etc. Anything other than dry and it tends to just wipe off. So I consider it a use for one op kind of thing.
Yeah, pretty much the same here. Don't count on the marker.If I'm scribing a line for a shoulder on a lathe I will mark it with a caliper and then use a tool to create a permanent mark so I don't have to worry about the oil or chips erasing my line.
We misinterpreted each other.Whiteboard markers are OK for making notes on your vise, but wipe off too easily for layout work.
The Staples Tru Red brand work better for me:
Pro tip!The Sharpies are ok for quick layout & a quick cut but I also find they don't last long. If you ever need to make a part that requires quite a bit of layout & handling then proper layout fluid is so much better. Even layout can wear off eventually depending on how much the workpiece is handled.
Sharpie for layout can also be harder to see depending on lighting. Layout fluid yields much better crisp & noticeable lines IMO. At work there are many times I can barely see a scribed line with Sharpie. We don't really necessarily need layout fluid at work (automotive related) and I'm not gonna bring my own so I deal with it.
But layout fluid whether in a bottle with brush, spray can, or dauber bottle can be cumbersome & messy. I see why so many people like to use a Sharpie.
Two words:Holy crap 24 packs? Do these things dry out quick? I haven't owned or used a Magnum 44 Sharpie in probably 2 decades, I lost it before it dried out. I buy regular Sharpies by the 12 pack & one pack will last me years.
You guys must be marking up everything! Even the small bottle of Dykem lasts me years.
Ah, crap. Sorry man!Thank you, looks like it was a one time sale, item sold when I checked.
