- Jan 25, 2015
- 2,558
I was walking through one of those "overstock" style clearance stores and ran across a V-twin compressor pump:
Part number was TL33724. They had "4HP" on the tag, but I l looked up the part number and comes out to a 3hp, 8.8 SCFM, max 1080 rpm pump and a 9.8" pulley on it. Cast iron heads, cylinder and gearbox.
Was only 75 bucks so I grabbed it. Cheaper than I have seen anywhere else for comparable specs and decent deal, even if it is a Chinese "something or other" brand.
I only have an oiless compressor on an upright 26 gallon tank and you can't even be in the same room with it when it's running. heck, I close the door to the untility room and sometimes I don't even want to be in the garage when it's running.
Not to mention, the oiless's SCFM is (to be kind) "poor". 4.2 SCFM at 90 psi. Won't even run my good impact guns at full power. So 8.8 SCFM will be a decent step up and as a side bonus it should run much quieter.
Looked though my stash of bits and bobs and sure enough, no 3 hp motors. Lots of fractional stuff, but no 3 HP jobs. So I grabbed a fairly generic "Vevor" 3 hp motor:
Nothing special, but will get the job done.
I don't have a 230 plug in the utility room, but I'll just bring and electrician in the new year to install one. Lots of room left in the panel and the compressor goes in the utility room right next to the panel, so cost shouldn't be that bad. Main line current is something I don't mess with (other than changing the occasional light fixture, switch replacement or such), so worth the dough to bring someone in to do it for me.
The thing is, I've only got a couple 3.2" pulleys. Not fractional stuff, they're cast iron (or cast steel, can't remember) and pretty hefty. 5/8" bore, 1/2" belt.
Problem is the 9.8 and 3.2 wok out to a 1126 rpm with a motor speed of 3450 rpm. Not a lot over 1080 rpm (46 rpm over), but still over. I'm not overly uncomfortable with a little over speed rpms, but ideally I'd like to be at the compressor rating of 1080 rpm max or perhaps a touch under it.
3.1" diameter works out to 1091 rpm and 3.0" dia works out to 1056 rpm.
Can I chuck it up in the lathe and shave a little off it without negatively effecting the v belt angle in the groove or should I recut the angle if I shave that 1/8" or 1/4" off the pulley?
I could just buy another 3.0" dia pulley, but they're not cheap (for stuff that's not fractional HP) and I've already spent more than I really should. Saving a few bucks on the pulley would be great if I can make what I already have here work.
No guesses please, I'm looking for an informed answer.
