F
f350ca
Forum Guest
Register Today
I want to repurpose a one ton truck frame, actually two that were repurposed for a sawmill frame, now I want to use the rails for the frame under my wood processor. I need the rails about 6 feet apart so I need to remove the cross members and make new ones.
In the past I've ground away or torch cut the rivet heads to remove them. Has anyone got any novel, quick, or easy method.
I have a magnet base drill, wonder if they could be drilled out?
Any suggestions appreciated.
Thanks
Greg
Thanks
Greg
