I have the complete assembly out from under the cabinet in my Heavy 10. Bearing retainer washers and bolts all removed. Set screws within the Cone Pulley loosened.
Is it just a matter of tapping the whole shaft out the the LEFT (since larger motor pulleys are on) - and sliding the cone pulley out to the right of the shaft -- to remove the shaft assembly. I need to get new bearings on this 47 yr old machine.
Don't want to start pounding and break the castings....
Any thoughts and tips about removal and re-install.....appreciated - thank you!
