- Nov 12, 2014
- 152
I have a LMS milling machine with the factory installed DRO. The machine is about 5 years old now and the outer insulation of the DRO cables are cracking and falling off. They still work okay but I would like to repair them. I sent a message to LMS and found replacement cables are no available. They suggested replacing the entire system or taking the cables apart and installing heat shrink over the cables. One approach is just too costly and the other very time consuming and not sure how diffaccult to take apart the cables and from which end would be the easiest. Kind of looks like the cables are molded onto the pickup/readers. I got to thinking about Plasti Dip. I've read a little about it but never used it. Would this be a suitable application for its use? Appears mostly it is used for coating metal tool handles. Has anyone used it on electronic cables?
