- Feb 18, 2016
- 451
I didn't see a tool & die section on the forum. So I'm not sure where to best post this first question. I'd like to get some ideas and feedback on various approaches to making tool and die fixtures for mass producing a large quantity of small parts.
As one example: I need to make a lot of really small gears. The gears are only 4.4 mm outside diameter and 0.5 mm thick. I can see approaching this problem two different ways. One is to make a long shaft formed to the profile of the gears, and then parting off each gear individually from there. The other method would be to use 0.5 mm sheet stock and make a punch and die to punch them out. I'm looking for a "retro" solution. No CNC or Laser cutting machines, etc.
A large part of this project is to preserve older machining technologies so there's more to the project than just making the parts.
These tiny gears also have a triangular shaped key way tab on the internal surface. That would be easy to make using the punch and die method. But I'm wondering how that would be done using the longer rod method. I'm thinking that a special broach would need to first be made to cut the center hole. Because it couldn't be just drilled out round. I'm thinking a smaller hole would need to be drilled through first, and then run the specialty broach through to finish the final form.
Here's a drawing of the gear. Note the tiny size. All dimensions are mm.
If it wasn't for that blasted keyway tab it would be a piece of cake. I could just drill and ream a round hole through it and be done with it.
Any retro tool and die makers out there?
Also is there a section dedicated to tool and die making on The Hobby Machinists forums? I have more questions concerning tool and die making.
Also is there a section dedicated to machining micro parts? Watch making? Etc.
The extremely small size of these parts is the real problem. If the gear above was say 4 inches in diameter instead of 4.4 mm it would be a piece of cake. Working with such small pieces eliminates a lot of procedures that could be used on larger items.
