Hi all,
Somewhere along the way, I ended up with some #28 drill bits that have a reverse twist on them.
Meaning they cut fine in reverse. (dzmn, e$#@, that bit sure is dull, Ohhhh!)
The only info I find is they are made for removing broken screws.
"When a reverse bit is inserted into a chuck and the drill is run counter-clockwise, this means that the bit performs the same sort of cutting action that a standard drill bit does when moving clockwise. This can be extremely useful as a method of screw extraction when the slots on a screw head have been worn away."
I don't see the advantage of reverse over forward drilling when "the slots on a screw head have been worn away."
The advantage I do see is you are not further tightening the screw by the drilling action, seems minor, but maybe helpful.
What is the purpose of a reverse twist drill bit?
Mikek
Mikek
